cancel
Job type :
Zip Code :
community forums
comments
Central Air Conditioning Units
Central air conditioning units are large machines that are designed to regulate the temperature inside a home. Rather than cool a single room, these units rely on duct works and vents to keep eachroom in a house at roughly the same temperature. Although they are complex, they do require standard care that most homeowners can tackle.
Central air conditioning units and their parts
Central air conditioning units have a number of small parts that enable them to cool and blow air. There are two main components in most central air conditioning units, however. They are:
  • The condenser – The condenser assembly of central air conditioning units are generally located outside a home. This major component includes a compressor, condenser coil and a fan.
  • The evaporator – Located inside the home, generally within a concealed space, is the evaporator. Central air conditioning units rely on this system and its blower and filter to pull air from inside a home into the unit to cool.
Caring for central air conditioning units
Central air conditioning units do require routine maintenance to function correctly. To keep central air conditioning units running right make sure to change filters on a regular basis, keep the condenser unit free of yard debris and clean the coils. Evaporator trays should be emptied and this part of the unit should be kept clean.
member comments
Did-it-myself Projects
updated by FelipeBR
did this on 9/22/2009
Iphone Bus Holder
updated by SolarPanel
did this on 8/29/2009
Home Build Solar System
updated by dorfin
did this on 3/30/2009
Recoil Starter Repair
How to Build a Shoe Storage Bench
sponsored articles of the day
