Login Error
Close
Ceramic Heater Safety: Advantages of Ceramic Heaters
by DoItYourself Staff
The several aspects of ceramic heater safety are well known. These heaters are compact and available in many different varieties. Whether you need to warm up a room in your home or just a small space, a ceramic heater is usually more than adequate. Ceramic heaters have several distinct advantages over other space heaters, some of which are outlined below.
Lower Risk of Fire
Ceramic heaters consist of ceramic plates and baffles that operate on the principle of convection. When the electricity is turned on, the coil and baffles get heated up. This heat is spread to the surrounding area. Larger models of ceramic heaters have fans, which help blow the hot air around. Unlike other space heaters, a ceramic heater is much less prone to starting an electric fire. This is because the ceramic elements do not get overheated. There is a much lower risk of surrounding articles catching fire. However, just like other space heaters, ceramic heaters also need a certain amount of clearance and free space around them.
No Toxic Emissions unlike Gas Heaters
Ceramic heaters are highly efficient and operate on electricity. This means that there is no danger of toxic emissions such as carbon monoxide in the vicinity. When operated properly, ceramic heaters also consume lower amounts of electricity than other space heaters.
Advanced Safety Features Available
Most ceramic heaters are available with safety features such as auto shut off, timer control and overheating sensors. Such features enable you to experience safer operation with less hassle. The overheating sensors allow for monitoring the heater for chances of overheating and excessive temperature. If the cutoff temperature is crossed, the heater is automatically shut off. In models that have timers, you can set the heater to operate for a fixed amount of time. After this interval, it will shut off.
Safer for Children
With other space heaters, you have to be very careful if there are children in the vicinity. There is always a risk of burns and scalding if someone gets too close to a heater. However, ceramic heaters are much safer because the heating elements remain somewhat cool to the touch. Even if there is an accident, the chances of burns are minimal. If, by accident, some piece of furniture of drapery is put too close to the heater, there is a very low risk of ignition due to overheating. All these factors make ceramic heaters the preferred choice for many different scenarios.
Drawbacks of Ceramic Heaters
Though ceramic heaters function cleanly and produce no emissions, it is important to remember that they operate on electricity, which is produced in a manner that is highly detrimental to the environment. Also, one must never take for granted the safety features of ceramic heaters. Just like all other appliances, they must be handled properly. If there is a malfunction or accident, there is always a chance of fire or electric shock.
 forum activity
