By utilizing cheap home security methods, a thrifty homeowner can often reduce the odds of their home being broken into and help protect their family–while also protecting the bottom line of their bank account. The goal of any inexpensive home security system should be to provide a warning if someone attempts to break into your home, installed at a cost you can afford.
A couple of cheap home security tips and tricks:
- Installation on wired home security models requires running some low-voltage wires. Consider investing in a wireless model, which operates on battery power and can be installed without that cost of wiring.
- Motion detectors are good security devices which cost very little. Motion detectors can be used in one of two fashions: they can be connected to lights or spotlights and set to turn the lights on if motion is detected, or hooked to an alarm system and set to trigger the alarm if motion is detected.
- Timed power strip devices are another inexpensive security device. These can be configured to turn on certain lights at specified times. This can give the illusion that someone is home even when the house is empty.
- Inexpensive security cameras are another effective cheap home security trick. They offer two benefits: First, their mere visible presence will help deter burglars from entering a home for fear of getting caught, and second, if a burglar does enter the home camera footage will make it much easier for police to track down the culprit.
Both wired and wireless models of security cameras exist on on the market that can integrate directly with an existing VCR or computer to record footage, which helps limit the cost of home security considerably. On wired models, a single low-voltage wire will be required to install and run the system.
Questions of a Do It Yourself nature should be submitted to our
