Login Error
Close
Cheap Ways to Improve Your Home Security
by DoItYourself Staff
Home security is the primary concern for most homeowners all over the world. We all feel the need to protect our homes and family from crimes such as burglaries and forced break ins. Here are a few guidelines to improve your home security.
Home security is essential and gadgetry like security systems and home alarm devices are a necessity. There are a few inexpensive ways that can prevent a burglary at your home.
  • Locking up correctly is the easiest way to avoid burglary. If you lock up carefully and use the right grade of locks, your home will be safer from most unwanted incidents. Always bear in mind that burglars find it easiest to break into your home through the garage door, then through the back door. Have both these areas secured with first grade locks that can make your home a less vulnerable target.
  • Having the basic security locks is not enough. You have to make your home impenetrable to burglars. You can do this by setting up your own alarm system and securing the most important valuables at home like jewelry or cash in high quality security safes.
When installing a home alarm system, there are a few things that you must consider:
The Boundaries of Your Home
The perimeter of your home should have no loop holes at all. Ensure that the whole perimeter is inspected thoroughly. Fix any broken hedges, fences and hatches in basements.
Using Alarm Devices and Motion Sensors
When you decide on installing electronic home security, use the minimum number of motion sensors. The rationale in doing this is that there would be fewer false alarms. False alarms can deter you from taking action even when there is a real problem. But having lesser number of alarm and motion sensors does not mean having a lax home security system. Use home alarm devices and motion sensors in locations that are strategic, such as corridors and hallways.
Home Alarm Devices That Make a Big Noise
You want a home alarm system that makes a lot of noise. The sound should be heard both inside and outside your home, alerting you to the presence of an intruder, and hopefully scaring the intruder away.
Home security systems can be advantageous to you not only in terms of security, but also in terms of resale value. A home that has a competent home security system in place with home alarm and electronic security devices, makes for a home with an added advantage when making a sale.
 forum activity
