Login Error
Close
Childproof Electrical Outlet Plugs
by DoItYourself Staff
If you are planning to become a parent or a daycare provider, you will need to consider using childproof electrical outlet plugs in your home. Thousands of people are injured every year in electrical accidents, largely due to the lack of taking safety precautions. Taking a few simple steps can prevent little ones in your home from being injured by electrical outlets.
Begin by inspecting all the outlets in your home. Pay special attention to any outlets that have broken covers or that are missing covers. If it’s not possible to repair or replace the outlet cover, move a piece of heavy furniture or a bookcase in front of the outlet to conceal it from curious hands.
The next step is to block access to all the working outlets. The easiest way to do this is to buy a package of plastic electrical outlet plugs from your local department or home improvement store. Each package contains several plugs and should cost less than five dollars. Place one plug into each open outlet. It will protect the children in your home in two ways; they will not be able to access the outlet and they will not be able to pull the plastic plug out easily.
Protecting children in your home from electrical outlets can be very easy. All you need to do is be aware of where the outlets are located in your home and how you can block access to them, either by using furniture or plastic plugs.
 forum activity
