Login Error
Close
Chipboard vs. Plywood For Cabinet Doors
by DoItYourself Staff
Chipboard is produced from recycled paper. It is also known as paperboard. This man-made material has various uses. One area in which it is frequently used is in making cabinet doors. Another commonly used material for cabinet doors is plywood. It is made by stacking thin slices of wood together. An adhesive is used to hold the wood slices together securely. You may be wondering which material makes a better choice. Below is a comparison of the two.
Pros of Chipboard for Cabinet Doors
It is an affordable option when used in place of plywood. Paperboard is a highly versatile material that can be made to resemble different types of wood. The appearance and quality are as close to any other authentic wood product you may want to achieve. With paperboard, you have flexibility in design and style of your cabinet doors. It is easy to use due to its lightweight nature. In spite of its being light, the material is resilient and sturdy. It does not easily give way under pressure. Cabinet doors are less likely to get dents or break when chipboard is used. It produces a stable final product without weak areas often associated with plywood. Your cabinet doors will be as strong as they look. Chipboard is more eco-friendly to use that plywood. It is made of recycled paper which guards against resource depletion.
Cons of Chipboard Cabinet Doors
Chipboard is easily damaged by water. Unless it is of higher grade, it tends to soak water. When saturated with water, it swells and disintegrates. Frequent constant with moisture will result in warping. Sealing or use of a protective cover is recommended to protect against moisture. This adds to overall costs. It is difficult to produce fine sheets with paperboard. This can create some limitations during installation. Thicker widths of chipboard require more effort when you have to cut through.
Pros of Plywood for Cabinet Doors
It is easy to use and work with. You can cut whatever shape you desire with little effort. Plywood is also available in various widths to suit your needs. Less effort is required to cut through plywood than chipboard. Plywood is a flexible material. You can bend or reshape it according to your design needs. Yet it will not splint or break. If you intend to make cabinet doors that curve outwards, plywood is an ideal material to use.
Cons of Plywood for Cabinet Doors
Plywood doesn’t stain well. This limits your color options. Plywood isn’t as durable as chipboard. Its manner of construction gives it a weak resistance to water. Cabinet doors in the bathroom and kitchen will easily absorb water through capillary. This encourages rot and damage of the doors. Temperature fluctuations also cause damage to plywood. You need to apply a protective coating or use a sealant to boost resilience. This makes plywood a high maintenance material. Cabinet doors made of plywood have a much shorter life span than those made of paperboard. This adds to your home maintenance costs.
 forum activity
