Choosing a Wide Baby Gate for Your Home
At certain places in your home, you may need a wide baby gate. These places often include the top of a stairway or a doorway between rooms, but different homes come with a variety of needs. Choosing the right baby gate is a matter of the utmost concern, for as babies become mobile, they want to go everywhere. Homes, as safe and comfortable as they are, can be perilous to a small child if unprotected. Childproofing doorways and stairwells is an absolute must.
For wide doorways and stairwells, you will need wide baby gates. You will find two primary types of baby gates: pressure-mounted and hardware-mounted.
Pressure-Mounted Gates
Pressure-mounted baby gates adjust to the size of the doorway and lock into place at the sides. For extra-wide openings, gates with longer extensions are required. You will find pressure-mounted gates easier to install. They are also portable, but the danger is that they can be pushed out of place with enough force.
Hardware-Mounted Gates
The alternative is a hardware-mounted gate. Although it requires a permanent attachment to the doorjamb, a strong or eager baby cannot push it out of place.
When choosing a wide baby gate, look into how easy it is to use. Make sure it doesn't offer easy ways for your baby to climb it or dislodge it. For extra-wide spaces, you may have to install a modular baby gate that links together.
