Choosing and Installing Modern Bathroom Mirrors
what you'll need
- Mirror
- Clips & screws (should be supplied with mirror)
- Drill
- Level
- Straight Edge
- Tape Measure
The addition of updated modern bathroom mirrors will give the feeling of a much larger space to your bathroom. Multiple mirrors are often used to enhance the light and expand the space even further. Depending on the type of mirror you choose for your bathroom, installing can be a do-it-yourself project. It is essential to realize when an installation is better left to the professionals. While most mirrors are direct and straight forward installations, if you have chosen a mirror with special hardware or shelving, the process becomes much more complex than just finding center, plumb and level.
Step 1 - Measure Area for Mirror
The primary factor in choosing a mirror for your bathroom is knowing the size constraints. Using a tape measure, determine the range of acceptable dimensions for your new mirror. Take into account the size and placement of the vanity, toilet, tub and all other furniture in the room. You can choose to place a combination of modern bathroom mirrors to make the room feel larger and lighter.
Step 2 - Choose Mirror
Your best source for determining which modern bathroom mirrors are best for your application is to do research on the Internet. There are numerous suppliers for modern mirrors. Most suppliers will guide you through your choice. Be sure that all mounting hardware is included with purchase. If not, be sure to purchase necessary hardware before installing the mirror.
Step 3 - Prepare Surface
If you are attaching modern bathroom mirrors in an existing bathroom, be sure that the surface is ready for installation. If a recessed medicine cabinet is being replaced, patch the hole in preparation for the new modern mirror. If patching is necessary, be sure to prime and paint the wall behind the mirror before installation.
Step 4 - Measure for Installation - Frameless Mirrors
Modern bathroom mirrors can be either frameless, or framed. For frameless mirrors, you will pre-install clips for hanging the mirror. Decide the elevation you would like the bottom of the mirror to sit. With a level and a straight edge, draw a horizontal line indicating the bottom of the mirror. Determine the exact center point of the mirror and measure equidistant out from that center to each bottom corner. This will be where the bottom clips are installed. With a drill, screw in the bottom clips. In the same manner, use a level and straight edge to measure vertically from each bottom corner to mark the top corners of the mirror. Install the top clips with drill and screws. (Clips and screws should be provided with the mirror). If you have chosen to install multiple mirrors, repeat the procedure on the remaining mirrors.
Step 5 - Installation of Framed Mirror
If your mirror choice includes a frame, installation will vary. Determine the top of the mirror elevation. With a tape measure, locate the position of the center of the mirror. At this point you will install a hanger for the framed mirror. Install with drill and wall anchors if necessary. Hang the mirror on the hanger. Adjust the mirror for level and plumb. With window cleaner and a clean rag (or paper towel) clean the mirror. Assess the location and verify plumb and level. Now stand back and admire your new modern bathroom mirrors.
