Login Error
Close
Choosing between Prefab Storage Buildings
by DoItYourself Staff
Prefabricated buildings, like prefab storage buildings, are also called modular buildings. They are becoming very popular in urban areas wherein the cost of construction in the traditional manner is very high. If you are planning to build a small storage space in your vacant backyard, a prefabricated storage shed is a sensible choice. Prefab storage buildings are inexpensive and easy-to-build. Most of them are retailed in do-it-yourself kits. A prefab shed can be easily relocated since it is undemanding in terms of periodic re-assembling (setting-up). However, choosing a prefabricated shed should be done with utmost care. Prefabricated sheds are retailed by home upgrading solution providers. According to customer requirements, these retailers provide easy-to-assemble, precut panels. Once an order has been placed and the assembly kit has been customized according to your instructions, it is nearly impossible to suggest any changes without incurring a financial penalty. Use the following information to understand various choices among prefab storage buildings.
Understanding Prefab Usage & Location
The most critical criterion for choosing a prefab building is its planned usage. Please understand that prefabs are available across a wide range of styling and pricing options. The price consideration for a prefab meant for basic storage, like a secondary garage, is considerably lower than prefabs retailed as office cabins. For basic storage, it is advisable to purchase standard prefab sheds, retailed in conventional sizes and designs. You can even buy a prefab that isn't painted. You can paint the prefab shed at home. This is an easy way to cutback on the prefab shed’s total cost. If you plan to store heavyweight goods that could strain the joints of the assembled prefab, enquire about the kind of framing used. The framing plays a critical role in the load-bearing capacity of the prefab and its overall durability. If moisture seepage is a major concern, instruct the prefab retailer to coat the prefab interiors with water-sealant coatings. If your backyard is exposed to extreme weather variations and moisture seepage, inform the prefab retailer about such issues. This decides the degree of insulation that is needed to make the prefabricated storage, weather-resistant. Many times, retailers offer external and internal, all-weather coatings in the form of a money-saving, packaged deal.
Legal Considerations
This is the most commonly ignored aspect about choosing a prefabricated storage. You should always check with your local/zonal administrators about any legal clauses that oppose the installation of a prefab. Most legal issues surface due to size considerations. Conventionally, there are guidelines dictating the size of any new construction, including prefabs, allowed beyond the main residential (the house) area. Construction codes may also restrict the kind of material used in the prefabricated building. Prefabs incorporating dense use of external metal framing and ultra-reflective paints tend to reflect light at sharp angles. Such a construction can be opposed by the local authorities on the grounds of causing public inconvenience.
Landscaping Considerations
Prefabs are often wrongly chosen, since their compatibility with the aesthetics of the outdoor space is ignored. The prefab’s overall appearance should blend in with its immediate surroundings—the house and the backyard space. Prefabs shouldn't compete with the house in terms of defining the external appearance of your residential space. Therefore, prefabs should be smaller than the residential space. If you plan to install the prefabricated storage shed near the garden, don’t use decorative, prefab accessories like wooden facades. Wooden additions tend to rot easily due to the moisture-rich, garden surroundings.
 forum activity
