Login Error
Close
Choosing Rear Surround Sound Speakers for Your Entertainment Room
by DoItYourself Staff
Rear surround sound speakers can enhance your home theater or gaming experience by leaps and bounds. So, having good quality speakers is very important if you really want to get the best out of your home entertainment system. Here are essential tips on how you can make sure that you only get the best rear surround speakers.
Tip 1 – Decide What Type of Rear Speakers to Use
First off, you need to decide on what type of rear speakers you want to install. You can choose bookshelf, floor-standing or satellite speakers depending on your preferences. For instance, the bookshelf type can save a lot of space but they are not that efficient in bass reproduction. Floor-standing rear speakers, on the other hand, have excellent impact and low-frequency response, but their size can take up a lot of space. Meanwhile, satellite speakers provide powerful sound despite their small size, but subwoofers must be added if you want to get the best out of this type of speakers. Both bookshelf and satellite speakers can be mounted on walls or put on tables and shelves.
There are also rear surround sound speakers that can be built into walls or ceilings. These speakers can provide top rate sound performance without taking up any space in your room, but they can be quite pricey. Besides, you will need minor wall or ceiling renovation to install them.
Tip 2 – Listen to the Sound Quality
After deciding on what type of speakers would be ideal in your room, you need to check the sound quality of each speaker set on your shortlist. This is a very important step because sound quality depends largely on your own preferences. But as a rule, good surround sound speakers do not allow high sounds to sound distorted as if they were made enclosed in tin cans. As you lower the volume to mid-range levels, the surround sound speaker should produce clear and crisp sounds. You can bring your favorite music CD to the store to help you effectively determine the best rear speakers for your place.
Tip 3 – Ensure that Rear Speakers can Blend with Other Components
Rear surround sound speakers are not subwoofers nor are they standard front speakers. So, make sure that your rear speakers do not function just like the other types of speakers in your home entertainment system. Rather than drown out the sounds from the other types of speakers, your rear surround sound should blend well with all the other speakers in the set. If you think that the rear speakers you are considering would sound too high-pitched even on a mid-range volume level, then such speakers will not blend in perfectly if you do not like blaring sounds.
Also, you need to ensure that your rear speakers can match the receiver or amplifier, if you are using one. Amplifiers have specific power requirements that allow them to support speakers. If the sound output of your rear speakers cannot be supported by the power of the amplifier, you will not be able to get the best out of your surround sound speakers.
 forum activity
