Choosing The Best Electrical Box For Your Home
Installing an electrical box in your home is something will probably come up in the future. Due to additions, or needing an extra outlet in a room, knowing how to go about installing an electrical box is a very valuable do it yourself type skill.
Besides knowing how to install an electrical box, you should also realize what different types of electrical boxes there are to choose from.
Plastic Boxes
A plastic electrical box is the perfect option when you are installing a box in an existing wall. You do not have to locate the studs and can install it anywhere in the wall. They are very easy to work with and are mounted in just a few minutes.
Metal Boxes
Metal electrical boxes are mostly used when there are exposed studs. A metal electrical box is also a great choice when installing a ceiling light or ceiling fan. Metal boxes are easily installed by nailing them to an exposed stud.
Weatherproof Boxes
When you have the need to install an electrical box outside, then a weatherproof type box is used to keep the wiring safe from water and the elements. They are usually plastic, but can be metal in a weatherproof housing.
