Choosing the Right Wood for Bed Slats
Bed slats are an important factor when building a bed. They need to be strong and robust enough to take the weight of two people and withstand further strains. Choosing the right wood is vital. You need a wood which will cope with a variety of pressures.
Douglas Fir Wood
Douglas fir is a light-colored wood with a vertical grain. It is highly resistant to warping and difficult to twist out of shape. Extremely durable, Douglas fir is used in many internal wood projects.
Southern Yellow Pine
Southern yellow pine is one of the strongest woods around and perfectly suited for use with bed slats. Its grain is firm and durable and will not break under the strain of constant weight.
Red Oak Wood
Red oak is a highly abundant hardwood and extremely strong. It is vastly resistant to wear and crushing.
Yellow Poplar Wood
Yellow poplar comes from the poplar tree and is very easy to work with. It has properties which make it simple to plane and stain. If you prefer to color your wood for your bed slats you will find yellow poplar very acceptable.
Hickory Wood
Hickory wood is a remarkably shock resistant wood and very resilient. Owing to its lightness it was actually used in the making of airplanes in the very early history of flight.
