Login Error
Close
Choosing which Type of Basement Ceiling Insulation Is Best for Your Project
by DoItYourself Staff
One of the main concerns of undertaking a basement ceiling insulation project at home is choosing which type of basement ceiling insulation is best suited for the project. Since saving on costs without compromising on quality is everyone’s prerogative and there is a limitless range of ceiling insulation types available in the market, it becomes hard to remain objective and make the right choice. Shopping from catalogs or in stores without prior knowledge of the pros and cons of each type of ceiling insulation can be an overwhelming experience and often people end up getting confused and make a wrong choice or spend too much money.
Different Types of Basement Ceiling Insulation
There are a wide array of basement ceiling insulation options available in the market these days. Each of these is specially suited to certain types of basements and the different kinds of budgets and functions.
  • Blanket Basement Ceiling Insulation: these can be in the form of rolls and bats and are often bought simply because they are very inexpensive. For those working on a budget and a large area to be insulated these kinds of insulation are undoubtedly the most popular as they are the easiest to put up while being light on the pocket as well. Cotton blankets or fiberglass blanket sheets are an example of this kind of basement ceiling insulation. The disadvantage of this kind of insulation is that it provides only a limited degree of control of thermal transfer.
  • Concrete Block Ceiling Insulation: these are ideal for newly constructed buildings and structures.
  • Foam Board Ceiling Insulation: this is slightly steeper in terms of price but provides a greater degree of insulation.
  • Loose Fill Ceiling Insulation: shredded newspapers and tightly packed pieces of other loose materials make for an excellent insulation layer. These can be more expensive to put together on the whole but are also effective.
  • Sprayed Foam Basement Ceiling Insulation: this is the most expensive kind of insulation and is best suited for basements that require no other work and are completely ready. It provides the greatest degree of insulation even in tiny spaces and hard to reach spots.
Choosing the Kind of Insulation to Use
The final choice of which kind of ceiling insulation is to be installed in the basement is dependent on a number of individual factors which come together to determine the strength of the choice on the whole. The following considerations have to be taken into account while selecting a ceiling insulation type:
  • Budget: the cost of the material used as well as the cost of installing the material has to be considered. One should take into consideration the initial expenses in terms of the long term energy saving and make a choice accordingly. For those working on a budget, fiberglass sheets are the best option but if one has money to spare, sprayed foam is the most long lasting and effective.
  • Space Available: insulation reduces the height of the basement. It is important to take space into account so that one continues to abide by the local building codes and regulations without creating a cramped or clustered room.
  • Local Weather Conditions: these have a significant impact on the insulation used and one should pick a material that can withstand the local climate.
 forum activity
