Login Error
Close
Cleaning Agents for Mold and Mildew Removal
by DoItYourself Staff
Removing mold and mildew is a problem that many homeowners face at some point. In order to successfully remove mold and mildew, you will need to make sure you use an appropriate cleaning agent. Here are a few cleaning agents you can use.
Borax
One of the best cleaning agents to help remove mold and mildew is borax. Borax is a product that is readily available with other cleaners at your local store. This is a white powder you can mix with water to form a paste consistency. Its abrasive properties help you scrub the mold and mildew off surfaces.
Bleach
Another cleaning agent you can use to remove mold and mildew is bleach. The bleach will help you disinfect the area.
Vinegar
If you want to use a typical household product, you should consider trying vinegar for the job. You can pour vinegar directly on the mold and mildew and then scrub it with a scrubbing brush.
 forum activity
