Cleaning and Maintenance Tips for Copper Gutters
Copper gutters can provide you with a beautiful feature on the outside of your home. However, you will need to perform regular maintenance to keep them looking good. Here are a few tips for cleaning and maintaining copper gutters.
Wear Gloves
Anytime that you are working with the copper gutters, you should wear gloves. You have oils on your hands that can damage the finish on the copper. Therefore, you should try to eliminate getting any of this oil on the surface of the copper gutters for best results.
Avoid Scratches
You should be careful with what tools you use to clean the gutters. Most of the time, you will want to use a soft plastic scoop in order to remove leaves and debris from the gutters. If you use a metal tool, it can easily scratch the surface of the copper.
Polishing the Copper
Periodically, you will want to make sure that you polish the copper. This will keep it looking beautiful for many years to come. You can clean the gutters with a mixture:
- 2 cups vinegar
- 2 cups salt
- 2 cups flour
Stir together to make a paste that you can apply to the gutters. Then thoroughly wipe it off and the gutters will look nice and clean again.
