Login Error
Close
Cleaning Grease Off of Kitchen Cabinets
by DoItYourself Staff
what you'll need
  • Rag cloth
  • Water
  • Dish washing liquid
  • Vacuum cleaner
  • Vinegar
  • Lime juice
  • Baking soda
  • Commercial cleaner
Kitchen cabinets have an important role to play in the overall visual appeal of your kitchen. Clean kitchen cabinets add to the beauty of the kitchen, whereas greasy, dirty cabinets can contribute to a rundown look. With regular cleaning and the right tools, you can keep your cabinets looking like new.
Step 1 – Clean Regularly
Cleaning the grease off of your kitchen cabinets can take a long time if you let it accumulate for many weeks or months. By keeping a regular cleaning schedule, you can minimize the time and effort you have to put in to keep your cabinets clean. Once every week, wipe off the exterior of the cabinet with a clean, damp rag cloth. If you spill anything greasy on the cabinets, clean it off immediately with some dish washing liquid and water. Remove any residue with a damp cloth and then wipe the cabinet dry.
Step 2 – Clear Cabinets Every Few Months
You must clear out all the contents of your cabinets and give them a deep cleaning once every couple of months. This will help in the prevention of excessive buildup of crumbs and food particles. Leaving the interior of the kitchen cabinets unclean can contribute to insect and pest infestation.
After you remove all the contents from the cabinets, check the expiry date on all of them and throw out those that are unusable. Depending on the grease and dust buildup on the containers, you can choose to wipe them down with a damp cloth or you can add some dish washing liquid to the cleaning solution. After emptying the cabinets, remove all the dirt and crumbs with a vacuum cleaner attachment.
Step 3 – Choose the Correct Cleaner
Dish washing liquid is safe and effective for the removal of grease from kitchen cabinets. However, if you have heavy grease buildup and grime on the cabinets, it may not be strong enough to do the job. In such a situation, you can choose a commercial cleaner that has grease cutting properties.
You must first test out such cleaners on an inconspicuous area of the cabinet before you apply them all over. A good testing spot is an interior corner of the cabinet. Look for any peeling or discoloration on the tested area. If there is any, do not use the cleaner. Natural cleaning alternatives include vinegar, lemon juice and a paste made from baking soda and water. You can apply these substances directly or mixed with water, depending on the amount of grime.
Step 4 – Clean the Cabinets
Depending on the cleaner you are using, you may have to mix it with water to create a solution and then apply it, or spray it on the area to be cleaned. After applying the cleaner, gently scrub the surface with a sponge or non-abrasive scrubber. Clean out the residue with a damp cloth and repeat if necessary. Finally, wipe down the area with a dry cloth to remove excess moisture.
 forum activity
