Cleaning Products for Granite Countertops
Choosing a proper cleaning products for your granite countertop is important. As a natural stone, granite is very porous and can be damaged by the wrong cleaner. Here are a few things to consider about the available cleaning products for granite countertops.
Stone Cleaners
When looking for cleaning products for granite, only consider cleaners that have been specially formulated to work on stone. Otherwise, you could run into problems that can not be repaired. There are many different commercial stone cleaners from sprays to granite wipes.
Soap and Water
Although it may seem simple, one of the most effective methods of cleaning granite countertops is to use soap and water. You can use liquid dish soap and warm water for best results. Use a rag to apply the soap and water to the countertop, and then rinse it off with clean water.
Bleach
When cleaning granite countertops, you will want to stay away from any cleaners that have harsh chemicals such as bleach. Bleach has been known to take the shiny finish off of granite and it can remove the color of the granite as well. Therefore, you will want to check any cleaning solutions for bleach before you put them on the surface of your granite.
