Login Error
Close
Cleaning Recycled Glass Countertops
by DoItYourself Staff
Cleaning glass countertops that are made from recycled glass requires no more special techniques than how you would clean a regular glass countertop. Using a recycled glass countertop provides a way to become more environmental responsible by repurposing material that has already been produced.
Use Standard Glass Cleaners
Standard household glass cleaning products are sufficient to use to clean and maintain your recycled glass countertops. You should clean the countertops on a consist and regular schedule, at least weekly. This will keep dirt and grime from building up and make your cleaning easier.
Use a Paper Towel for Everyday Spills
Everyday spills and stains that occur can be wiped up using a paper towel and warm water or a mild soap. Just wipe the stain or spill and discard the paper towel. Occasionally wipe the countertops with a rag to remove dust particles from forming.
A common sense approach to cleaning is all that is needed to keep your recycled glass countertops clean and clear. There are no special materials or cleaning solutions that you need and be weary o any such claims. Soap, water or a mild cleaning solution will do the trick and save you from spending money on a product that is not necessary to keep your countertops clean.
 forum activity
