Login Error
Close
Cleaning Rubber Flooring Tiles
by DoItYourself Staff
what you'll need
  • A broom
  • A vacuum
  • A bucket
  • Water
  • Liquid detergent
  • A sponge
  • Cleaning cloths
Rubber flooring tiles are easy and simple to clean. You can use household items you will find in your kitchen cupboards to clean the tiles. Regular cleaning will keep the tiles looking new.
Step 1 – Removing Dust and Dirt
Use your broom to sweep away any dirt on the rubber tiles. Continue the process with your vacuum. This step will remove any dust or residue stuck in the rubber tiles.
Step 2 – Mixing a Cleaning Solution
Pour a gallon of warm water into your bucket. Add three squirts of liquid detergent to the water. Mix the solution together until the water is soapy.
Step 3 – Washing the Tiles
Immerse your sponge into the cleaning solution. Squeeze any excess liquid out of the sponge. Use the sponge to wash your rubber tiles. Empty the bucket when you are finished washing the tiles. Clean any dirt and debris from the bucket and the sponge.
Step 4 – Rinsing the Tiles
Pour a gallon of cool, clear water to your bucket. Immerse your sponge into the water and then squeeze out the excess water. Use the sponge to rinse the tiles. Buff the rubber floor tiles dry with your cleaning cloths.
 forum activity
