Cleaning Rust off Cast Iron
what you'll need
- Oil
- Cleansing Solution
- Salt
- Scrubbing material
Cleaning rust off cast iron is necessary to keep the cast iron in good condition. This is not a complicated job and can be completed during the weekend when you are free. Here's how you do it.
Step 1 – Method One
Apply a cleaning solution on the rust affected area and allow the solution to work.
Step 2 – Alternative
Soak the cast iron in a vinegar solution.
Step 3 – Let it Sit
Allow the cast iron to sit in the solution for some time.
Step 4 – Scrub
Remove the cast iron and scrub with force.
Step 5 – Repeat
Repeat the above process till the rust wears off.
Step 6 – Wash
The next step in the cleansing rust process is to wash the cast iron with soap and rinse it.
Step 7 – Dry
Wipe of the excess water and then let it dry naturally.
Step 8 - Second Method for Cleaning Rust
Add three spoons of salt and add vegetable oil.
Step 9 – Paper Towel
Get some paper towels.
Step 10 – Scrub
Scrub the salt and oil mixture with a paper towel.
Step 11 – Steel Wool
If the rust does not budge then use steel wool to scrub.
Step 12 – Continue
Continue scrubbing till the rusts start wearing off.
Step 13 – Wash
Wash the cast iron with soap.
Step 14 – Hot water
Use hot water to wash the cast iron.
Step 15 – Dry
Let the cast iron dry out in the open.
Step 16 – Finishing
Check the cast iron after it has dried to see if any rust remains.
