Login Error
Close
Cleaning Stainless Steel Sinks: 3 Mistakes to Avoid
by DoItYourself Staff
Cleaning stainless steel sinks to preserve their beauty and keep them their best is very simple. Though durable and not prone to chipping like porcelain does, however, stainless steel does scratch easily. For best results with your cleaning, follow the tips below.
Avoid Using Abrasive Cleansers or Cleansing Products
Because stainless steel will scratch easily, it is important that you never use abrasive cleansers or cleaning tools such as steel wool, stiff wire brushes, etc.
Avoid Leaving Items in the Sink
Although it’s often tempting to allow pots and pans and even water to remain in your stainless steel sink overnight, it could be a costly mistake in doing this. The grime on your soiled pans can potentially leave stains and marks in your sink that may be difficult to remove, as can sitting water. It’s also important that you thoroughly remove all traces of any cleaning product you use.
Avoid Chlorine and Bleach
Many manufacturers recommend not using harsh chemical products like chlorine or bleach in your stainless steel sink.
 forum activity
