Login Error
Close
Cleaning Tips for Acrylic Shower Enclosures
by DoItYourself Staff
Cleaning an acrylic shower enclosure is completely different than cleaning a fiberglass enclosure or a ceramic tile enclosure. A bit more care with cleaning products must be observed.
Prevention
Acrylic shower enclosures scratch easily and also are more prone to hard water stains. You may want to consider a water softener to help alleviate this if you live in a hard water area. Also, be aggressive in keeping the enclosure dry, so wipe it down with a towel after each use to keep it looking new.
Cleaning Do's and Don'ts
The first most important guideline is don't use an acid based cleanser such as Lime Away or KLR. This will pit the acrylic. Also do not use vinegar. Don't use scouring powder or steel wool or ammonia.
Use a gentle all purpose cleaner that doesn't contain any of the above ingredients. Read the label of your favorite household cleaner to double check. There are several cleaners on the market specifically for this area or you can also check with the manufacturer of your enclosure for suggestions. If you have stubborn stains, try scouring them with baking soda on a wet rag. Always rinse your enclosure and wipe it dry after cleaning.
 forum activity
