Login Error
Close
Cleaning Your P Trap: Are Drain Snakes Useful?
by DoItYourself Staff
Cleaning out a p trap drain can be a difficult task when it gets clogged up. However, there are some ways that you can effectively clean it out. For example, you might try cleaning it out with a drain snake. Here are a few things to consider about whether a drain snake can be useful when cleaning out a P trap.
Drain Snake
A drain snake is a tool that is also referred to as an auger. This tool is referred to as a drain snake because it is flexible, long, and narrow as if it were a snake. This tool is designed to be able to be pushed down through the drain pipe. It is flexible, so it can go around the corners and help clean out the P trap.
Effectiveness
In most cases, drain snakes can be very useful and effective. They are a tool that anyone can use and they often get results. These tools can be pressed down into the pipe and can help break up clogs inside them. They have been known to be effective where other methods such as a plunger or chemicals have not. Therefore, these tools can be very useful in this area.
 forum activity
