Cleaning-Up After a Basement Leak
what you'll need
- Polyurethane Fill
- Cartridges for Polyurethane
- Crack-Seal Glue
- Peel-Off Ports
- Water-Proofing Kit
- Bucket
- Rags
- Cleaning Solution
A basement leak can not only cause damage to the carpeting, walls, and personal possessions, but also may cause serious mold problems. It’s important to know how to find water leaks in your basement and to know the best way to clean up after a leak has occurred. Repairing basement leaks is not complicated, but is something that should be done as soon as possible to avoid serious damage. The following 5 steps will help you do this:
Step 1 – Find the Cause
It would be difficult to repair something if you don’t have a clue about the cause or location of the source of trouble. Some things that contribute to basement leaks are
- Leaky seams from concrete expansion and contraction (caused by extreme temperature changes)
- Poor drainage around the foundation
- A faulty foundation
- Heavy rainfall
- Irrigation or sprinkler pipe problems
- Leaking pipes
If basement leakage problems appear to be a serious, it would be best for you to hire professional clean-up people to do the job.
Step 2 – Clean your Work Area
Before filling cracks where the leaks have occurred, it is important to clean as thoroughly as possibl the wall or floor areas where leakage occurred. Use a bucket of water and disinfectant to wipe the area completely. This is crucial so that you can get rid of toxins caused by build-up of algae, and so that the wall or floor where the leak occurred will be completely clean. Without this thorough cleaning you may find that polyurethane will not adhere as well to surfaces.
Step 3 – Cover the Cracks
A word of caution about covering the cracks: It’s important that you never drill into the cracks in attempt to fix them, as this could cause even more water seepage. Use the crack-seal glue and the peel-off ports to cover each and every crack. Instead, fill the cracks with the cartridges of polyurethane. The polyurethane forms a foamy like substance and expands up to 30 times which allows it to fill the cracks. Once the polyurethane completely dries, a water-proof material is produced that will last up to 15 years. After filling the cracks, allow ample time for the foam mixture to completely solidify after it has mixed with water.
Step 4 – Remove Crack-Seal Glue and Peel-Off Ports
Once the polyurethane mixture has thoroughly dried, peel off the crack-seal glue and peel-off ports.
Step 5 – Apply Water-Proofing
Now you have sealed off the cracks, use the water-proofing kit to keep the cracks dry. You can buy water-proofing kits at your local hardware or building supply store. Follow the manufacturer’s directions for kit usage.
