Login Error
Close
Closet Organizers Made Easy
by DoItYourself Staff
Start with closet organizers if you want to get more organized at home. Getting organized at home appears to be daunting task, but It becomes easy if you break it up into smaller jobs and handle one task at a time. Well constructed closet organizers are a great way to give a neat and organized look to closets.
Get Organized
The first step towards getting organized, however, is to remove unwanted elements, the dress that is no longer in style, the pants that you cannot fit into unless you lose that extra fat, or shoes that you will never wear again.
Sort out things that will need to be hung and the ones that can be placed in boxes or filed in a cabinet. See if you need more shelves or more space to accommodate shoes or hang clothes. Now is the time to look for closet organizers that will meet these needs.
Choose the Right Type for you
There is a wide variety of closet organizers available in the market to suit all budgets. You can get closet organizers made of laminate, wood, metal, melamine and wire. You are bound to find one that suits your style and budget.
Basically there are two types of closet organizers, namely, closet organizer kits and closet organizer systems. Depending upon your budget you can choose the one that suits you the most.
Do-it-yourself closet organizers are cheap and require very little effort in assembling. Kits for closet organizers are supplied with the necessary components that include shelving and hardware. There may be a need for drilling but normally cutting is not required. Besides the basic closet organizer you may also look for accessories like shoe racks, shelves and drawers.
System closet organizers are fully assembled pieces. You will be required to measure your closet and look for the correct size. You have two options here. You either go for a pre-fabricated system if that suits your needs. You can also try to mix and match various components to come up with a style that fits your requirements.
If money is no constraint then you can opt for customized closet organizers. You can even create your own design online or ask for a consultant to view your closet and design one to suit your personal style.
Regardless of whether you need one for your bedroom, nursery or a walk-in closet there are closet organizers for virtually every room and need. Closet organizers are convenient and a simple solution for organizing your home.
 forum activity
