Clothing Stain Removal
Clothing stain removal should be done as a delicate process. Depending on the type of material the clothing is and what the tag reads for cleaning; will determine if you should follow the below clothing stain removal process.
It is important with any stain that clothing stain removal be done immediately if at all possible. Allowing the stain to set in will create more difficulty in removing it.
Clothing Stain Removal Process
Always rinse the clothing in cold water and try to remove as much of the stain as possible. Clothing stain removal should be done gently, not to create fraying of the fabric. Gently blot the stain, removing as much as possible and rinse each time.
You can use products that are designed for clothing stain removal, gentle soaps, and even shampoos and gently rub the stain out, blot and rinse. Repeat the process until the clothing stain removal is complete.
You may want to add a clothing stain removal product to the area that was stained before washing the item of clothing. Check to ensure the stain is completely gone before placing the clothing in the clothes dryer.
