Login Error
Close
Coffee Bean Plant Care Tips
by DoItYourself Staff
A coffee bean plant is very sensitive to its surroundings. The type and quality of care it gets is important to its survival and growth. The following article will show you how to care for your very own coffee bean plant.
Light is Important
Most coffee bean plants are found growing in warm climates. While many plants will thrive and adapt to whatever conditions you give them, coffee bean plants are a little more sensitive. Position your plants in an area that has medium light, like near a shady window. If the plant does get direct sunlight, take care in limiting it to an hour a day.
Be Mindful of the Temperature
The coffee plant is meant to be grown in areas with mild to hot temperatures. Keep a thermometer in the area so you can make sure the temperature never drops below 65 degrees Fahrenheit.
Humidity is Crucial
Coffee bean plants naturally thrive in areas that are high in humidity. To simulte these conditions, mist your plants with water several times a week. You will know if the coffee bean plant is failing because the leaves will begin to brown at the tips. You can also add a tray of pebbles under the pot.
Potting Mix Moisture
Keep the potting mix moist during the spring, summer and fall. When winter comes, allow the potting mix to partially dry out. Keep a eye on the coffee bean plant to look for any signs of wilting. If you spot wilting then water the coffee bean plant immediately. The leaves of the plant are very delicate and giving the plant an immediate fix of moisture could very well save them. Never allow the coffee bean plant to wilt for more than a day.
Re-potting the Coffee Bean Plant
The coffee bean plant is constantly growing so every spring it is important that you re-pot it into a pot that is one size larger than the previous one.
Watch for Harmful Insects
The health of the coffee bean plant is always in jeopardy; be it from soil that is too wet or too dry, too much sunlight or not enough to a pot that is too small. Insects are also a major concern with the main culprit being scale insects. These insects are commonly known to infest the underside of the leaves and look like small yellow or brown spots. On first glance they may appear to be part of the leaf. Simply wipe them off with slightly soapy water then apply a pesticide.
 forum activity
