College Dorm Furniture: How to Make Your Own Pin Up Board
Save money on your college dorm furniture budget by creating your own pin-up board. Customize your own bulletin board by making it yourself with inexpensive supplies. Follow the instructions below to build a board made of cardboard or one make of plywood.
Cardboard Pin-Up Board - Tools and Materials
- Corrugated cardboard
- Fabric
- Thumbtacks
- Push pins
Step 1 - Cut Cardboard
Get a piece of thick corrugated cardboard from a paper store or use a cardboard box. Cut cardboard to desired size.
Step 2 - Cut Fabric
Purchase a piece of fabric or use an old shirt. Cut fabric 2 to 3 inches bigger than the cardboard.
Step 3 - Attach Fabric
Wrap fabric snugly around the cardboard and fasten it in back with thumbtacks. Attach to wall with push pins on all 4 corners for a pin-up board that costs almost nothing.
Plywood Pin-Up Board - Tools and Materials
- Thin plywood
- Foam board
- Fabric
- Glue
- Staple gun
- Mounting brackets
Step 1 - Cut Plywood
Purchase a thin sheet of plywood from your local home improvement store. Have it cut to the size you desire.
Step 2 - Attach Foam Board
Get a piece of thick foam board from your local craft store and cut it to the same size as the plywood. Glue it to the plywood and let it dry.
Cut fabric 3 inches bigger than plywood, wrap it snugly around foam board and plywood. Attach in back with staple gun. Attach mounting brackets and hang it up.
