Login Error
Close
Colored Fluorescent Light Bulbs
by DoItYourself Staff
Using colored fluorescent light bulbs is a way to change the mood or feeling in a room or office work area. Colored fluorescent light bulbs are available in full length or size or in compact fluorescent tubes, CFT. The spiral CFT is also known as the “Compact Fluorescent Light” or CFL. All of these come in colors including red, yellow, blue and green. Cost for the standard tube is from $10 to $15 depending on location and availability. The colored Spiral Compact Fluorescent light bulbs are in the same price range as above.
Colored Filters
The colored fluorescent light bulb is an option for decorating for parties or  special events. If there are budgetary constraints, there is also an option to use colored tubes which will cover standard fluorescent tubes. Although these may be cost effective in the short run, consideration should be give to all safety issues that encasing a tube in a removable material may cause.
Mixing Colors
If the desire is to create a particular mood with colored fluorescent light bulbs, it might be considered to use more than one color in a setting. Using and mixing the primary colors, red, blue and yellow, it is possible to use a mix of colored fluorescent light bulbs to bring a specific color theme to the event.
 forum activity
