Login Error
Close
Common Circuit Breaker Problems
by DoItYourself Staff
The most common circuit breaker problems occur when the circuit is left unprotected and the wire carrying the high voltage tends to heat up to a melting point causing damage and fire. Mentioned below are a few common circuit breaker problems:
Miswiring of the electrical system
Most often, the reason behind circuit breakdown is the miswiring of the electrical system. This problem can lead to improper shutting down of the electrical device. The electrical device may continue running even after the switch is shut down.
Another result of miswiring can be an electric shock. Generally this type of electrical shock is not critical, but it can have harmful effects on people using electrical home appliances. Miswiring can damage your appliances, switches and other electrical devices permanently or cause temporary operating problems.
You can surely cure a problem of this extent by reviewing the circuits that are affected and by testing the electrical system completely.
Tripped Circuit Breaker: Circuit Overload
You might have faced the problem of tripped circuit breakers. This problem happens frequently due to circuit overload. This happens when too many electronic devices are plugged or operated into a single electronic outlet. If you use too many electronic appliances plugged in one location, the single circuit will get overloaded and trip or switch off to lighten the load. The main idea behind tripping is to protect the circuit s from getting overloaded. The circuit breaker mechanism has been specially designed to protect the electrical system in households.
You can easily prevent circuit overload by following a few electrical safety tips. One method is by avoiding plugging much electronic equipment in one outlet. Turn off those devices which are not in use and also check for any loose connections in your outlets.
Short Circuit
One more common circuit breaker problems is short circuit. Short circuits can lead to tripped circuit breakers. Short circuits take place when a hot wire touches another neutral wire. This leads to the tripping of the circuit breaker because of the electrical current overload. Short circuits can be a serious problem. The main problem is in the electrical wiring hence; it is advisable to get it checked immediately to avoid further serious damage.
If you ever notice a short circuit in your device plugged into the outlet, do check the exterior of the cord.  Check for a burning odor. Replace or repair the wires if you find them damaged. Exposed wires can pose a serious threat as they have electrical current flowing through them.
These are the common circuit breaker problems which need to be taken care of. You can easily avoid such problems by following certain procedures to ensure efficient working of the electrical system of your home.
 forum activity
