Composite or Wood Deck: Cost Comparison
Composite deck cost can be quite a burden and if you are going to build yourself a deck or are renovating your existing one, one of your considerations should be the materials. You can choose between a composite or wood deck and both have their own advantages and disadvantages. But the biggest difference between the two is that wood is a natural material while a composite is man made, using plastic and recycled wood fibers for materials.
Cost of the Project
If you are going to include professional installation fees, a wood decking can cost you around 10 to 24 dollars for every square foot. A composite decking on the other hand runs at 20 dollars per square foot. Depending on the scope of your project, building a composite or wood deck can range from 4,000 to 25,000 dollars.
Type of Wood
The type of wood that you choose for your deck will gre atly affect the amount that you have to shell out for the project. Some kinds of wood such as the yellow southern pine will cost you around 10 dollars to 16 dollars per square foot that is installed on your deck. Other types like the cedar and redwood will run from 18 dollars to 22 dollars per square foot installed on the deck. Hardwoods that are like teak can cost even higher. The amount can range from 22 dollars to 24 dollars per square foot. Such amounts include the cost for a professional installation.
Installation Cost
If you have computed the cost of materials for your deck, expect to pay double if you are going to have a professional install them. But while it could take a lot of time and there are many complications in the construction of a new deck, a do-it-yourself-er with above average skills can do it. A do-it-yourself project for a small deck will cost you between 500 to 1000 dollars.
Features of the Materials
Each type of composite decking or wood material has certain features that you can take advantage of, and contributes to the average price that is place on each square foot of material. Cedar and redwood deck materials have such a high cost because it is estimated that they can last for as long as 20 years. The yellow southern pine on the other hand is usually pressure treated when it will be used as a deck material, increasing its price. Teak wood is usually chosen as a decking material because of its durability. However, the most durable material you can use for a deck must be composite decking, which is the reason why it is one of the most costly materials available for a deck.
Extra Costs
No matter what material you use, there are always extra costs that will be incurred in the project. If you are going to add railing and benches for example, it could add to the overall cost of your project. Further increase will happen if you are going to construct a multilevel deck with stairs. A wood or composite multilevel deck can range from 16,000 to 25,000 dollars.
