Login Error
Close
Concise Planning and Budgeting for Your Bathroom Renovation
by DoItYourself Staff
Bathroom renovation programs have become very popular nowadays, whether you are doing a DIY project or hiring a professional. Hiring a professional is the best way to go as your bathroom is in good hands for sure. Second to the kitchen, the bathroom is the next most popular room in the house to renovate. Of course, before starting the renovation, there is the planning to do. The planning is an important part of the whole project because it gives you an idea what your bathroom will look like according to how much you afford to spend.
The Budget
There are a series of questions to ask yourself before starting to plan your bathroom renovation. Asking these questions will help you see better what is needed and what is not and therefore, you are saving money in the process. For instance, determine what type of finishes and upgrades you would like. Do you need to do something about the humidity of the bathroom? Check the layout of the present bathroom so as not to repeat mistakes. If you can’t even open the door without hitting the toilet, you should try to use a different layout. Also determine whether you need to seek professional help or whether can you try to do it all on your own. Perhaps you want only a small makeover rather than completely renovating your bathroom. In all these cases, take note and then establish how much you can afford to spend while planning how to meet all the needs.
Hiring a Professional
With all the budding building codes and the tough work needed to renovating your bathroom, it is often recommended to hire a professional. The most common question asked when hiring a professional to do the work is whether the service provider is a bathroom specialist or whether he works on various types of renovations.
Planning Your Bathroom Renovation Design
Make sure you plan the layout well, according to the space you have available. Try to work around your plumbing because moving it will cost you.
Choosing Fixtures, Sinks and Toilets
Changing your fixtures is one of the easiest ways to give your bathroom a different look. Higher quality fixtures will last longer but they will cost you. When choosing sinks and toilets, you will want to pair these two together. Choose the same designs for both of them so you will not have many different designs. Too many designs in one room can be an eyesore. When it comes to buying a toilet, you don’t have to go for the most expensive ones, but don’t go for the cheap ones either. Investing in a low flush dual flush toilet will save you money on your monthly bill.
Tubs and Showers
The first thing to decide is if you are going to have a tub, a shower or a tub and shower in the same room. Your decision must depend on your space and your budget. If you have the room and the money it is always better to go for the free standing shower and a separate tub. If space demands you can only have a small tub, go for a deep one. If you are going to buy a shower, it is best to stick to materials that are easy to maintain and clean.
Mirrors, Lighting and Flooring
If the lighting is not sufficient, your bathroom will look awful, no matter how beautiful the materials chosen are. Mirrors should always be incorporated well with the lighting design. When it comes to flooring, you will want something that is waterproof and easy to clean. The best option is ceramic, marble or stone tiles as they are all waterproof and easy to clean.
 forum activity
