Concrete Floor Covering Options
Concrete floor covering continues to be one of the most popular for homeowners. When used in flooring, concrete has consistently proved to be a suitable material. It has established itself as one of the most durable, attractive and cost-effective options. With concrete, homeowners have access to a wider variety in floor design and style. Below is a guide for some of the more common concrete flooring options.
Stamped Concrete
It is one of the most popular decorative concrete flooring types. Rigid patterns are imprinted into a freshly cast colored concrete floor. The versatility that stamped concrete avails appeals to many. The stamped surface can be created to resemble tiles, cobblestones, flagstone, bricks, slate, marble or any other desired surface. Stamped concrete can also be used to create a hardwood floor look. Planks of real hardwood are used to create stamps that are then imprinted onto the floor.
Stenciled Concrete
It is achieved using stencils. A huge paper stencil is laid over freshly cast concrete. The stencil is cut according to a desired style or pattern. The stencil is allowed a few hours to set into the concrete. Once the concrete has dried well, the stencil is removed to reveal the outcome. Stenciled concrete gives homeowners the option of achieving various decorative looks with minimal effort.
Scored Concrete
Shallow cuts are made onto a concrete floor surface while it is still wet. Some specialized blade is used to make the cuts. The cuts are made to resemble grout lines or geometric designs. The scoring technique can be used to achieve a tiled floor look on a concrete floor.
Stained Concrete
Concrete floors can be stained to achieve the look of natural stone. This is done by applying acrylic or acid stain to the floor surface when wet. The chemicals in the acid react with salt compounds in the concrete to produce a mottled look that resembles stone. The floor surface will bear some darker areas just like stone.
Tiled Concrete
Concrete tiles are installed like most other tile varieties. However, concrete tiles are much heavier than other tiles. Concrete tiles offer more versatility than other types. They’re available in greater variety of shapes and sizes than the usual standard squares. You’ll enjoy more flexibility with concrete tiles should you opt to incorporate embeds, imprints or sculptured designs.
Concrete with Polymer Coating
A polymer coating may be poured over a preexisting concrete floor. It is a great way of rehabilitating an old or worn out concrete floor. The advantage of using a polymer coating on a concrete floor is that chips and cracks will be filled in. Different colors and patterns can be created with a polymer coating. Flakes can also be added to a polymer coating for a decorative effect.
Polished Concrete
A concrete floor can be polished to resemble the finest marble. A high powered polishing machine is used to polish the concrete floor to an extremely smooth and glass-like finish. Polished concrete floors are available in various colors. The surface can also be grooved so that it appears to be composed of individual slabs of marble.
