Login Error
Close
Concrete Pool Construction: Planning Guide
by DoItYourself Staff
When it comes to installing a pool in the backyard, most people prefer a concrete pool construction. This kind of a pool is generally in ground and is structurally the strongest. It is robust and long lasting, which makes it a great investment. The reason they are so strong is because they are mostly made from shotcrete and gunite.
Concrete inground swimming pools that have been custom designed are the most popular ones as they offer many superior features to other kinds of swimming pools. These are also easier to update or remodel when they become old. A simple resurfacing of this kind of pool is enough to make them look brand new again. There are a number of things to consider while installing a concrete swimming pool in your home. Here are some important tips that you can use:
Work with a professional contractor
The most important thing to remember when you plan on installing a concrete swimming pool in your backyard is to hire a professional contractor. Doing this will ensure that you are aware of every detail and this can help eliminate unexpected costs and frustration during the building process.
The design and size
The first thing that you and the swimming pool contractor have to do is decide the size of the pool. This is done taking into consideration the area of the available space, surrounding tiling and ensuring there is enough space to move about in the backyard. Once a decision has been made regarding the size and shape of the pool, the depth of the pool has to be decided. Most concrete swimming pools have oblique floorings which help to vary the depth from one end to the other.
Excavating and laying foundations
When the size, shape and depth have been decided, the excavation process begins. This is the main reason for hiring professional builders. They have the required equipment and necessary skills for excavating the ground and laying the foundation for the pool. Concrete pools usually have steel placed around the edges first to give it strong sides which are then plastered with concrete and leveled out.
Piping and earthwork
As the base and sides for the swimming pool are being constructed and leveled, the piping is fitted. This is done with utmost care as it concerns letting fresh water into the pool, draining out and recycling used water and letting it back into the pool. Masonry retaining walls are also installed to keep water from seeping out. These walls are then tiled.
When this is done, you can select the finishing touches you want. This can include installing underwater lights, diving boards, ladders, slides and water fountains. The area around the pool would also require tiling so that the pool water does not get dirty from stepping into mug or grass and then going into the pool. This is the final step in designing and building a concrete in-ground swimming pool in your home.
 forum activity
