Login Error
Close
Concrete Pool Decks vs Paver Pool Decks
by DoItYourself Staff
Once you have installed your pool, it is time to decide between paver and concrete pool decks or other types of materials. While concrete and pavers are similar materials, there are a few key differences between them. Consider the following as you narrow down the choices for your pool deck.
Repairs
One of the biggest differences between these two types of decks is in how you can repair them. If the concrete pool deck cracks or chips, it will be very difficult to repair. You can try to patch the concrete, but it will most likely stand out because the color will be a little bit different. When you try to patch concrete, it ofetn looks worse than if you simply left it untouched.
If a paver in a deck is damaged, you can easily fix the situation. You can get another paver and put it in the same spot. This makes paver pool decks very durable because you can easily repair any damage.
Cleaning
When it comes to cleaning these pool decks, concrete definitely has the upper hand. With concrete, you get a solid surface that is much easier to clean. You do not have to worry about things getting down in the cracks like you do with pavers. You can simply wash the concrete off with a hose or even with a power sprayer.
With pavers, it might be difficult to clean because you are working with several smaller pieces. A power sprayer can uproot the sand or other material in between the pavers and holding them in place.
Installation
Another way that these two types of deck differ is in the installation. You will most likely want a professional to install a concrete pool deck for you. While you can technically pour the concrete yourself, it is a process that has to be done correctly all at once. If you make any mistakes, it could have a devastating effect on the quality of the deck overall.
On the other hand, you can easily install a paver deck yourself. You handle each individual piece when putting it in, which makes it a lot easier for the novice. If you make a mistake with pavers, you can simply correct it and move on. You are not racing against the clock before it dries permanently like you have to with concrete.
Cost
When it comes to cost, concrete is generally a little less expensive than pavers. Pavers are priced per piece, and when you have several hundred or thousand pavers, this can add up very quickly. Concrete is generally more cost-effective, and the cost usually includes the installation labor as well.
Look
Both of these decks will give you a unique look for the area around your pool. If you prefer a solid surface, go with a concrete deck. Otherwise, keep in mind that you can use pavers to create a unique and customized deck.
 forum activity
