Login Error
Close
Consider Using Eco-Friendly Recycled Concrete
by DoItYourself Staff
A slightly cheaper and useful form of concrete, called recycled concrete is being increasingly recommended for household and commercial construction purposes. Homeowners should consider using recycled concrete for its greater eco-friendliness apart from many other advantages explained below.
Recycled Concrete Basics
Recycled concrete is much cheaper than new concrete retailed in the market. In fact, it is among the most affordable structural fillers. The recycling process doesn’t add substantially towards the final costing of recycled concrete.
Secondly, many residential areas required to pay a certain tax at the time of using structural fillers. This tax is referred to as landfill tax and it proposes various taxes that are affected by the kind of filler material used for laying the foundation. Since, opting for recycled concrete means contributing towards limiting the landfill problem, lower taxes are applied—a major cost-saver.
Recycled Concrete Is Green, Eco-friendly Resource
Homeowners wanting to adopt greener construction practices are seriously advised to consider recycled concrete. The many ways in which using recycled concrete contributes towards environmental preservation, include:
  • Avoiding Landfill Problem—nearly every kind of constructional refuse including concrete is eventually directed towards landfill sites that are a major environmental hazard. Using recycled concrete means a direct contribution towards curbing the landfill problem.
  • Reducing Gravel Mining Problem—recycled concrete is used as a substitute for gravel used in structural filling. This reduces the dependency on ecologically-destructive gravel mining practices.
  • Reducing Pollution—recycling of concrete is done via mechanical machines, and some not-so-toxic chemicals. In fact, chemical treatment is needed only when the original concrete is suspected of having excessive amounts of chemical contaminants. Use of recycled concrete means that transportation needed for excavating and transporting the refuse concrete is saved upon which directly contributes towards controlling automobile pollution.
One of the most popular, contemporary uses of recycled concrete is its usage in the 2012 Olympic Village wherein the organizing authorities are trying to highlight green building practices.
Recycled Concrete Is Cheaper
Secondly, many residential areas are required to pay a certain tax at the time of using structural fillers. Usually, this tax is referred to as landfill tax though it is more relevant in commercial zones. However, the use of recycled concrete helps to cut costs as it allows you to pay a lower landfill tax .
Recycled Concrete Has Multiple Residential Applications
Recycled concrete is often referred to a reused concrete. This might invoke the perception that this is a sub-standard, cheaper version of concrete that may have compromised strength and durability. However, such apprehensions are misplaced.
Firstly, recycled concrete isn't considered unsafe for building purposes. This is essentially because its usage is limited to certain aspects of construction. Recycled concrete is ideally recommended for land-filling purposes associated with laying foundation of homes or laying the basement. This is why recycled concrete is often referred to as an eco-friendly structural filler.
It is also used for filling drainage structures, pavement underlay and creating barriers around the garden or any outdoor space. It can also be used for raising the garden in the form of a ground-filler.
Some landscapers source different types of recycled concrete where the bigger bits are used for forming landscaping borders or soil binding purposes. The finely-crushed concrete bits are used as gravel in outdoors apart from being used in the mortar-mix used for repairing or installing private fences and other kinds of residential boundaries.
 forum activity
