Login Error
Close
Construction Permits vs. Building Permits
by DoItYourself Staff
Construction permits are essential for any building projects, but have you ever stopped to consider the difference between construction and building permits? Finding out the type of permit that you need to apply for in advance will make it much easier. Permits are a legal requirement and failing to apply for the right one can end up costing a lot of money, or even result in you having to take down your new buildings.
Construction Permit
A construction permit is a document required to allow an individual or business to construct any form of building, or alterations to a building. Construction permits are documents which are commonly required in almost all states and countries all around the world. Without a construction permit any alterations to your property may not be legal.
Construction permits are essential for all types of permanent construction. Depending on the type of structure you are installing you may or may not require a construction permit. Sheds and other temporary structures don't normally require any type of construction permit. If you are building a fence over a certain height, planning permission, or construction permits may be required.
A construction permit will make sure that everything you are proposing to do to your home is permitted. Certain types of property may be protected and this means that it's not possible to extend or alter them. It's important to make sure that you can change your house how you want to.
Building Permits
A building permit is exactly the same as a construction permit, however it is used to build new properties from scratch, including new houses, apartment blocks and office buildings. A building permit is harder to apply for because you will need to apply for permission to build houses on land which is not currently built on.
As not all land can be built on legally, you will have to research the restrictions on the land you wan to develop.
It's essential that you get the right building permission and the necessary permits required to build various structures. By getting the right permits you will avoid fines and work delays. If you go ahead and build without the proper permits, you expose yourself to penalties, including having to take the structure down after you've build it.
The right permits for construction projects will also assure that the meet safety standards. It's important to adhere to building regulations because these codes are in place for a reason and public safety is one of them.
Applying for Permits
The method of applying for building and construction permits will vary depending on the state that you live in. You can get all the information necessary at your state government's website. Leave ample time for the permit process, because it can take weeks or months for your permits to come through.
 forum activity
