Login Error
Close
Continuity Tester: Essential Info and Other Home Repair Tools
by DoItYourself Staff
A continuity tester is one of the important electrical tools to keep at home. It is used to determine whether circuit breakers work properly. Maybe you think that most people would not need it at home, but actually you could really benefit from having one around the house. Especially if you are fixing things at home yourself you will definitely need it when dealing with electricity.
Operation of the Continuity Tester
A continuity tester can determine whether electricity is flowing or if there is an obstacle that preventing a proper connection. The tester can check all the cords and wires in electrical systems and circuits, ensuring that electrical power gets through. The tester features a battery located inside that sends electricity to the wires. If the prong that exists on the other end receives the electrical power sent the tester will notify you that everything is OK. Usually this happens with a buzzer or a small light that lights up. If there is no signal of any kind, it means that something is probably blocking the flow of power.
Continuity testers are easy to use; the only thing you need to do is plug their alligator cord on to the prong of the cord or wire you want to check and connect the tester tip to the other end. In general you can find these testers at any local hardware store. They cost around $5-8 and they include a battery, test wires, a probe, and an alligator clip. The probe is attached to the one end of the battery case, and the clip at the other one.
Continuity testers are absolutely safe to use, but you have to keep in mind that you have to turn off the current in order to be able to see if the electrical power flows from the one part to the other: this will also help you determine which the problematic spot is. If you are testing a device or an appliance you should also unplug it and turn the power off for safety.
Home and Electrical Tools
Home tools and electrical tools are necessary in home improvement tasks; if you are fond of DIY tasks you should have some tools in your tool box and garage. For instance, a power painter can help you paint an entire room within minutes; while a steamer or stripper can help you remove paint or wallpaper fast and effectively. Electrical tools can also help you accomplish home repair tasks easily, such as plumbing tasks.
There is a wide range of electrical tools available, for all sorts of workshops. These tools range from simple electric screwdrivers to hammer drills, nailers, staplers, and more. You can also find electric sanders, such as belt sanders, orbitals, or disk sanders that make sanding easier, manageable, and faster. Of course, you should not forget about saws, wrenches, and ratchets which are useful both in the house and outside.
 forum activity
