Login Error
Close
Control TV Glare With Home Window Tint
by DoItYourself Staff
The installation of home window tint can help alleviate a common problem, glare from the setting sun disrupting the television screen.
TV Glare
Undoubtedly it has happened to you at least once in your life. You’re relaxing in front of the television and watching your favorite show. Then the sun cuts through and shines directly on the screen. You know it will eventually go away, but the glare is still an annoyance.
Home Window Tint
To fix it, you can draw the blinds or curtains, tilt the TV away from the glare or hold your hand up and block it. Another option is to apply home window tint to the window the sun shines through. Home window tint won’t turn the window into a complete mirror, but it will darken the window sufficiently to cut down on glare from the sun.
In addition to controlling glare, home window tint can keep some of the sun’s harmful ultraviolet rays from entering your home. It also provides a certain amount of privacy.
 forum activity
