Convert An Outdoor Stove Into A Barbecue Grill
One of the best ways to get a unique barbecue grill for your next gathering is by turning your outdoor stove into your grill. This can give you a new and convenient way to cook for your guests on a grill that will have the neighborhood talking.
Better Than a Store-Bought Barbecue
When you turn your outdoor stove into a barbecue grill, you can create it in any way that you want. You can make it large or small and customize it with any number of features. When shopping for mass-manufactured grills, however, you are limited to the few standard sizes, styles and extras that you can find in stores. Why spend more money on a brand new grill when you already have most of the equipment you need to make one yourself?
Safety
Whenever you work with gas-fueled devices like your outdoor stove or barbecue grill, turn off the gas before working. This will prevent any fuel spills and accidental fires. The fuel lines that you use to fuel your gas grill or outdoor stove should be intact and not cracked in any way. Leaking fuel lines can lead to a fire.
Older Outdoor Stoves
In the past, outdoor stoves were fueled with wood or coal. These were when people were away from home and needed a place to cook. When you convert one of these smaller stoves to a barbecue grill, you may want to change the fuel used to power it from wood or coal to gas.
Using more than one outdoor stove can provide you with more cooking area for your grill. In fact, you are not limited to the size of the grill that you create.
Larger Outdoor Stoves
There are also outdoor stoves available that will provide you with more cooking space. The outdoor stove is designed to withstand various climates and all sorts of weather conditions without becoming damaged. They are hearty appliances that are the perfect choice for making a barbecue.
Accessories
Because an outdoor stove is designed for cooking out of doors and not necessarily for grilling food, it might be necessary to change the grill surface of the stove. You can find accessories and replacement grill racks in most home improvement stores.
Build a holder for the gas tanks that you will be using for fuel. Many people choose to have a rack on the bottom of the grill to keep the tanks with a shut off valve that will stop the flow of gas whenever the grill is not in use.
