Login Error
Close
Convert Hinged to Sliding Mirrored Medicine Cabinet Doors
by DoItYourself Staff
what you'll need
  • Screwdriver
  • Sliding doors
  • Sliding door tracks
  • Hacksaw
  • Tape measure
  • Pencil
Converting an old medicine cabinet into a mirrored medicine cabinet can add functionality and décor to any bathroom. Without the need to buy and install a brand new cabinet, you can simply replace the doors of your existing cabinet with sliding mirrored doors. The new door will create the look and feel of a new cabinet with only a fraction of the work required.
Step 1 – Remove Hinged Doors
Remove the existing doors from the cabinet. To remove the hinged doors, you need to use your screwdriver to loosen and remove the screws attaching the door to the hinges on the outside of the cabinet.
Step 2 – Remove Brackets
After removing the cabinet door(s), you also need to remove the hinge brackets. The brackets should be secured to the cabinet with screws as well. Remove the attaching bracket screws from the cabinet and then remove the brackets.
Step 3 – Measure for Tracks
Install the tracks into the cabinet for the sliding doors. The top track and bottom track need to align exactly with each other and the face of the cabinet for the doors to slide smoothly. Align your tape measure to the far left hand side of the cabinet and measure 1 inch inward from the opening of the cabinet. Make a mark at this point.
Now move the tape measure to the middle of the cabinet and make another mark 1 inch inward from the opening of the cabinet. Repeat this same step for the far right hand side of the cabinet. Now draw a straight line connecting the three 1 inch marks to create a placement line for the bottom track. You need to repeat these steps for the top of the cabinet as well.
Step 4 – Install the Tracks
Now that you have your track lines marked, you are ready to install the tracks into the cabinet. The tracks should have come with installation screws which you need to use. Lay the backside of the bottom track even with the track line you created in the bottom of the cabinet. This line should ensure that your track is aligned and even. Using the included screws, attach the bottom track to the cabinet. Repeat this step for installing the top track into the top of the cabinet.
Step 5 – Install the Doors
You are ready to install the sliding door into the tracks. This is easiest to accomplish if you have removed the shelves from inside the cabinet first. Insert the top of the first sliding door into the bottom track and then maneuver the top of the door backwards into the cabinet. Now as you pull the top of the sliding door forward to straighten it, you should be able to fit the top of the door into the top track. Check the door by sliding it once or twice. Repeat this step with the second door and then reinsert the shelves when both doors are attached and sliding properly.
 forum activity
