Convert Regular Mini Lights into Battery-Operated Christmas Lights
what you'll need
- Batteries
- Christmas lights
- Weatherproof battery enclosure
- Weatherproof electrical tape
Battery-operated Christmas lights are much easier to install than other types. Using battery-powered Christmas lights also means that you don't have to plug lights into an electric socket inside or outside the house.
Battery-operated Christmas lights are available in all sorts of different colors and designs. You can also convert regular lights into battery-powered Christmas lights if you want.
Step 1 - Choose Suitable Christmas Lights
You need to choose Christmas lights which are suitable for battery power. Although it's actually possible to convert almost any lights to run on batteries, you will find it easiest if you use DC LED Christmas lights. Make sure the lights do not run off mains electricity without using a transformer. It's important that a transformer is used to step the voltage down.
Step 2 - Perform Calculations
Take a look at the transformer which came with the lights and take a look at the rating of the lights. Also look at the voltage so you can work out how many batteries to use. The number of batteries required will depend on the voltage.
You may want to consider using rechargeable batteries so you can disconnect them and charge them up when they run down.
Step 3 - Choose Battery Housings
Depending on the type of batteries you decide to use, you will need to choose battery housings. Because you're installing these lights outdoors, you will need to use weatherproof battery housings, which will not let the water come into contact with the batteries.
Step 4 - Connect the Wiring
After you've bought the necessary components, you can begin to connect everything. Start by cutting the power transformer off the lights and exposing the bare wire. Then connect the wires from the Christmas lights into the battery pack.
Make sure that everything is wired correctly. You must also ensure that all the joints are weatherproof. Use electrical tape to protect the bare electrical contacts and bare wires from the elements. If you're using heat-shrinking tape, you will need to use a heat gun to shrink the tape.
Step 5 - Install the Battery-Operated Christmas Lights
Install your battery-operated Christmas light outside. Make sure that you also find a way to hold the batteries in place without letting them sit in your gutter. The lights themselves should come with mounting clips and hooks. You can use tape or screws to hold the battery packs somewhere out of sight.
Step 6 - Add Enhancements (Optional)
Many additional enhancements can make the project even better. For example, you might decide to add solar panels and a charge controller so you never have to worry about charging or replacing the batteries yourself.
