Login Error
Close
Converting a Bunk Bed into a Loft Bed
by DoItYourself Staff
what you'll need
  • screwdriver orallen wrench (depending on the style of bed)
  • sockets and ratchet
  • small L brackets
There are many reasons for converting a bunk bed into a loft bed. One of the most common times to consider this change is when one of your children has moved out of the room. Another reason to convert your child's room would be to save space by putting a desk or entertainment area under the loft bed. Whatever your reason may be, this is not a hard project. Not only can this conversion save space, but most children really like the look. There are very few tools and materials needed to accomplish this type of project. Most of this project consists of removing parts that are already on the bed. Consider the following step to quickly convert your bunk bed into a loft bed.
Step 1- Remove the Bottom Bed
The first thing you need to do is remove the mattress from the bottom bunk bed. You can save this mattress for use with another twin bed. However, in some cases a bunk bed mattress is longer than a standard twin bed. In addition, some mattresses have the box springs built into the mattress. If your mattress is too long or has springs you will only be able to use it with a bunk bed frame.
Step 2- Determine Your Frame Style
 forum activity
