Copper Rain Gutter Repair: Mistakes to Avoid
Copper rain gutters provide a traditional and attractive addition to your house. There are some important mistakes that you should avoid when repairing copper rain gutters as they can be fragile and you can inadvertently cause further damage necessitating a complete replacement.
Repairing Copper Rain Gutters
It is important to avoid repairing these rain gutters yourself unless you are familiar with working with copper. The job does require some special skills. You will also need some important tools and materials such as rivets and solder. You will also need to have a general knowledge of sweating joints and seams. If you do not, it is best to get a professional to do the job for you.
Soldering Copper Rain Gutters
It is also important to remember that you can not use sealant with copper gutter repair. This is because the sealant will not expand or contract with the metal as it will with other materials. Because of this, the joints need to be soldered together to create a completely watertight connection. This will allow the entire section of the gutter to be as weatherproof as possible. In this respect, the entire installation acts as a single unit, rather than separate pieces.
