Cork Flooring Durability: How Long will it Last?
Cork flooring durability is an issue that many potential buyers wonder about. Cork has become a very popular flooring choice for a number of different applications, and the durability is one of the main reasons why. Here are the basics of what you can expect from cork flooring as far as durability.
One of the important considerations with cork flooring durability is what kind of conditions the cork is installed in. The more traffic that the cork flooring has on it, the shorter amount of time it will last. Another factor is how much abuse it takes during its lifespan.
With a typical cork product, you could expect it to last from 10 to 20 years under normal circumstances. If you purchase one of the higher-end cork flooring products, you could realistically expect it to last from 20 to 30 years. There have been instances where a cork floor lasted for 50 years without any problems whatsoever. However, that is not the norm and you should expect it to experience a little bit of wear and tear over the years.
Cork flooring is very resilient and can stand up to a lot. When you scratch or dent the floor, it will typically bounce back to its original shape at some point.
