Cost Effective Exterior Window Trim
Exterior trim on the window will enhance the curb appeal of the look of any home. The type of trim that is chosen to finish off a plain looking window can provide great character, style, and even depth to the exterior of a home. Selecting the right exterior window trim is very important not only for the look, but for the resale value of the home.
Wide Range of Options
When looking at the exterior trim options for the windows in your home you will notice that there are plenty of options to choose from. Everything from wood, metal, vinyl, PVC, rubber, and molded laminate are available to homeowners and do-it-yourselfers. These different trim pieces will also have a wide range of prices from $20 for an 8-foot length to well over $300.
Cost Effectiveness in Trim
Many people today are looking at cost effective measures for enhancing the look of their home. The cost of wood pieces are rising, so homeowners are looking at many different alternatives to using wood trim. The cost effectiveness is not only limited to the actual cost of the material. The long term cost is also a factor. Many new alternatives in exterior trim do not require a lot of maintenance or replacement. This means lower overall costs.
Vinyl Exterior Trim
The mos common today is a vinyl exterior trim. This type of material is very low maintenance and will not break the bank when it comes to purchasing it. Installation of the vinyl exterior trim is fairly straightforward and does not include any special instructions.
Fiberboard Exterior Trim
One of the types of exterior trim that is rising quickly in popularity is that of fiberboard cement trim. This type of trim is very resistant to rotting and fire. The new line of low density fiberboard cement trim is 30 percent less dense than regular fiberboard which makes it much easier to cut, handle, and install. While the initial cost of this type of trim may be more than wood or vinyl, it will last for many years without any maintenance needs.
Particleboard or OSB
Another choice that is becoming popular today is the use of OSB trim or particleboard. The reason for the popularity of this type of wood is because it will hold paint much better than regular wood trim. This means better protection over several years without constant repainting. The cost is also lower than most trim choices.
Polyurethane Exterior Trim
This type of exterior trim has been in use for over 30 years in the U.S. It is a popular way to trim off the exterior portions of a home. It is created by pouring the polymer liquid into a rubber mold. Once it is dry, the mold is removed and the polyurethane exterior trim is ready to use. The different shapes that can be used are limitless.
Foamed Polystyrene Exterior Trim
For a long time polystyrene trim has been used on the interior of the home. With recent advancements in the way that it can withstand UV rays, polystyrene foam can now be taken outside. While the initial cost of the foam is much cheaper than other products, it does need to be maintained with paint and sealer.
