Login Error
Close
Cost Effective Garage Floor Covering Solutions
by DoItYourself Staff
If you are looking for garage floor covering, there are many different potential options for you to consider. However, you will notice that some of the options are more expensive than others. Here are a few cost effective garage floor covering solutions.
Paint
One of the easiest and most cost-effective solutions for you to consider for your garage floor is paint. Painting the floor can be a very easy way to cover your floor. You should be able to purchase a few gallons of paint and apply it to the floor in a single day. You should be able to use either epoxy or latex paint. Epoxy paint is the most preferred covering for garage floors because of its durability. You will need to get a paintbrush or paint roller in order to apply this to the floor. When you compare this to some of the other options that are out there for garage floors, this is going to be your cheapest option by far.
Stain
Many people also choose to stain the concrete in their garages. Staining concrete is also a relatively simple solution. You will be able to apply the stain to the concrete and completely change the look and color of the space. This will be more expensive than painting the floor but it will be cheaper than installing most other materials that are available.
Peel and Stick Tile
Another option that you might consider is a peel and stick tile. There are several peel and stick tiles that are marketed as garage floor covering solutions. This method will be extremely easy for you to install and will not require a lot of manual labor. You will also not have to worry about using a lot of tools or purchasing adhesive either. You simply peel the backing off of the tile and then place it on the floor.
Mats
Many homeowners also choose to install mats in their garages. Many of these products are made out of rubber and are very durable. They do not have a confusing installation process for you to worry about. You will simply have to lay them down the ground before you use them. This will provide you with a very durable flooring surface for your garage that will stand up to a lot of wear and tear. This option will not provide you with a uniform flooring surface, but it will be better than walking on a plain concrete floor.
 forum activity
