Login Error
Close
Countertop Resurfacing
by DoItYourself Staff
Countertop resurfacing or countertop refinishing are excellent solutions to making changes to your kitchen décor on a budget. Your kitchen can have a brand new look without the costs associated with replacing kitchen countertops, which can be quite costly.
Countertop Resurfacing With Style
Undertaking the remodelling of a kitchen can be a bit daunting, especially with the cost of everything today and countertops are certainly not cheap to replace. But a simple countertop resurfacing project can do a great job of giving your kitchen a whole new look. Countertop resurfacing can give your kitchen the visual impact you desire with cost of a full remodel.
Countertop Resurfacing Requirements
There are two requirements for countertop resurfacing: The cabinets have to be in good condition, and the countertop itself must not be warped or damaged
Countertop Resurfacing Steps:
1. Take your measurements and start shopping for replacement laminate. Laminate material comes in a wide range of textures, styles, and colors so decide what you want your kitchen décor to look like. If you have standard cabinet sizes you can actually buy sheets of laminate which are pre-cut.
2. Prepare your surface. You will need to strip off the old glue first. You can by chemical stripper at any home improvement store.
3. Once you’ve removed the old glue you need to sand the surface smooth to create proper adherence.
4. Spread the new glue thinly on the surface. Make sure it’s even by using a glue spreader. This is very important or you could have bubbles that can cause an uneven countertop surface.
5. Place your laminate in place and use a heavy roller to get even adherence. Wipe away any glue that seeps out the edges.
Countertop Refinishing
This method is even cheaper than countertop resurfacing. With wood countertops it’s simply a sand, stain or paint, and seal process. If you have laminate countertops you can even repaint those. When done correctly they stand up well.
 forum activity
