Countertop Stove Pros and Cons
Installing a countertop stove has become a popular trend in new houses these days. This type of stove can provide you with a number of benefits. However, it also has a few drawbacks associated with it as well. Here are some of the pros and cons with installing a countertop stove.
Pros
- Looks: One of the best things about this type of stove is the look that it provides. Countertop stoves are typically sleek and smooth. They blend in with the counter, and they do not stand out and take away from the other features of the kitchen.
- Easy cleaning: Another great thing about this type of stove is that it is typically easy to clean. You can just spray the smooth surface with a cleaner and wipe it off when needed.
Cons
- Cost: Installing a countertop stove is not exactly cheap. You will spend more on this type of stove than you would by purchasing a more traditional model.
- More space: When you install a countertop stove, you have to devote somewhere else in the kitchen for the oven. Now you need two separate areas instead of the one space where a traditional oven and range would fit.
