Login Error
Close
Crawl Space Encapsulation Explained
by DoItYourself Staff
If your crawl space suffers from mold, chronic dirt, and humidity, then you may wish to consider crawl space encapsulation as a solution. This technology separates the crawl space and the ground using a vapor barrier, creating an additional envelope of protection between the building and outside weather. Crawl space encapsulation is one of a number of energy-saving processes which will help reduce heating bills, and ensure that your home is more energy efficient.
Installing Crawl Space Encapsulation
Before you consider installing crawl space encapsulation systems, make sure that your crawl space is protected against vermin and fungi: these can both damage the seal around the vapor barrier.
Check how your crawl space will be sealed against moisture. The best crawl space encapsulation methods involve more than simply putting down a later of plastic liner. Installing a low-grade liner like this will not do much to prevent humidity and mold from regrowing, and it is better to purchase a better standard of vapor barrier.
Crawl space encapsulation can prolong the life of your crawl space, as it reduces temperatures, and limits humidity, making it less vulnerable to insects such as termites, and fungi that can decay wood. it can also greatly improve the air quality, both in the crawl space and in the home itself.
 forum activity
